Fuel Transfer pump
Old 10-06-2007, 02:55 PM
Spirit615's Avatar
Spirit615
Spirit615 is offline
Fuel Transfer pump
Hello,
I wanted some opinions on what type of fuel transfer pump I should get.
I want to buy biodiesl in bulk, and I will need a pump to get it from the barrel into my truck. Any opinions on that?
Old 10-09-2007, 08:45 AM
Corey872's Avatar
Corey872
Corey872 is offline
There should be a wide array of options...do you want to use a hand pump, electric, air, 12VDC, 120 or 240 VAC, variable speed, auto on / auto off or a switch, plain hose or an actual dispenser nozzle, how fast do you want it to go, how much do you want to spend, do you want to meter the gallons as you pump, or just know that some fuel is going in, do you want a filter and water separator on the pump or just trust what is coming out of the bulk tank. You may also want to consider if the fuel / pump is going to get cold during the winter and/or be exposed to the weather year around.
The guys over on the biodiesel forum might have a little more insight on what set-up's they use. But basically, choose your options above, then look for materials like Teflon, Viton and Nylon for seals and valves and steel, stainless steel or aluminum metals. Stay away from Natural rubber, nitrile, polypropylene, PVC and Tygon, as they are attacked by biodiesel while brass, bronze, copper, lead, tin, zinc accelerate the oxidation process.
Old 10-14-2007, 02:25 AM
cowchasinsix's Avatar
cowchasinsix
cowchasinsix is offline
When buying a pump make sure that the manufacuter explicitly says that it is compatable with motor fuels. Usually not a big deal but there are pumps out there which are not supposed to be used with fuel.
Old 10-14-2007, 02:12 PM
manfredo's Avatar
manfredo
manfredo is offline
1991 F 150 dual tanks when switching from R to F engine dies
sglass57
6.4L Power Stroke Diesel
06-11-2013 05:10 AM
jedijeb
02-20-2012 09:11 AM
ford4x4956
09-15-2009 09:28 PM
Billy Brethren
General Automotive Discussion
04-20-2005 12:23 AM
airtractrdrivr
Modular V10 (6.8l)
05-23-2004 06:28 PM
Quick Reply: Fuel Transfer pump
