setting timing
Old Sep 8, 2007 | 06:48 PM
beaners1's Avatar
beaners1
setting timing
I know it'sbeen discussed before, what is the timing on an 88 5.8L? What do I need to remove to get the correct timing since there is no vacuum advance.
Old Sep 8, 2007 | 07:55 PM
Eric C.'s Avatar
Eric C.
In the harness going to the distributer is a item called a SPOUT. In just plugs in and is a little bigger than a plug in type fuse. Just pull it out, set your timing, and plug it back in. No problem.
Old Sep 8, 2007 | 08:24 PM
beaners1's Avatar
beaners1
What is the timing degrees, 15,20, or what? Thanks for the info on the spout.
Old Sep 8, 2007 | 08:25 PM
jroehl's Avatar
jroehl
Timing should be 10*BTDC.
Jason
Old Sep 9, 2007 | 09:02 AM
beaners1's Avatar
beaners1
OK, just to help me clarify the spout, it has two wires on it that don't go anywhere, they go in and then there is a plug. I know the wires go somewhere just don't know how to describe it better.
Thanks for the help, should have the truck running today after 3 months of sitting and getting the engine rebuilt. Very excited.
