What's the correct way to interpret drag race ET's?
Originally Posted by bdrummonds
Cool links, Genes gonna have an anuerism disecting the formulas that were used to make these calculators.
Gene, be careful traveling to Duluth, I know you will be, but I say this cause last week while towing the 5er through ATL, I was brake checked by the same guy 4 times in 2 miles. He was a drunk and thought he was being funny. I ended up flat patching my trailer tires and had to replace them when we got home due to his arrogance/ignorance. Had I not had my wife and 2 kids in the truck, I probably would have just run over him after the second time, but their saftey comes first. I did get a trooper on channel 9, and he did respond, but could not get to the guy before he got off the interstate.
I think some people see a person towing a large fiver as a target to mess with.
Originally Posted by S_Harvey
As rusty asked in post number 8, just above your past response, are you trying to make a HP calculator? Because as he said, there are quite a few available on the 'net.
If you have something else in mind, I can try and find a bunch of my time slips for my Lightning and send you the info. Stewart
EDIT Talking about speed, you can see how slow my connection is at my new location, I was waiting a good 5 min to post while you responded to my last!
Originally Posted by ernesteugene
BTW, rustydailey, Age=?, etc..., I couldn't find you in the FTE 7.3L age database! If you want to be included in the next update post here on the thread, how old is everyone? https://www.ford-trucks.com/forums/s...0&goto=newpost
Sorry those links wouldn't work.
Rusty
Originally Posted by phil6608
Auto tranny 3 speed with OD, with OD off/ 6000 pounds GVW with driver/4.10 gears.
It's no longer a 4X4.I took out the T case/front diff and Axel shafts.
Actually, I don't really need it, but my final display sheet won't reflect your MPH vs RPM correctly without it. I manually input engine HP estimates for each fractional second until I get the ET's to match the measured ones. Then, for each 0.5 MPH as speed increases during a run, I display the RPM as a reference. I assume a broad power band between about 2400 to 3200 RPM, because that's what is typical from dyno runs for a PSD. If your's is different please note that as well. Your result will be posted on a new thread with something like "new improved model" in the title
I've already done a sheet for 320 max HP because that seems to have a broader range of interest to what others have. I'm going to post that sheet first (if my slow connection lets me), but it doesn't come close to matching your ET's. I just hope dialing in enough HP to match your #'s doesn't blow up my computer, which my gut feel is telling me might be what's about to happen with your PSD using nitrous.
If anyone else wants to post as many #'s as they've got for a given run, like in the above format used by phil6608, I'll do runs for those as well. Since my model updates every fraction of a second throughout the run, I can adjust the HP accordingly to match 60', 330', 660' (1/8 mi), 1000", and 1320' (1/4 mi) points exactly. Just make sure all points are from the same run, don't mix in your best from different runs as if they're all from the same run.
Here's my new drag race model, post your ET's here if you want an estimate of HP. https://www.ford-trucks.com/forums/635809-new-improved-drag-race-model-im-open-for-business.html
ernesteugene
08-28-2007 10:06 PM
ernesteugene
16
08-28-2007 04:12 AM
ernesteugene
08-25-2007 04:48 PM
ernesteugene
07-22-2007 04:04 PM
