Egr Trouble Code
Old Jul 2, 2007 | 07:36 PM
w8jumper's Avatar
w8jumper
Exclamation Egr Trouble Code
I have an 03 F-350 with PSD with MBRP 4in turbo back exhaust, S&B intake, and Edge Juice w/ attitude. I replaced my muffler with a delete pipe about a week ago and soon as I started her up got a check engine light. Maybe a coincidence but when I pulled the code it was P0401, EGR flow insufficient. My MPG's have also tanked in the last week. Thinking the EGR might have something to do with that. I was thinking I would just disconnect the EGR and clear the code. Can any one tell me if the two are related or is it just weird timing.
Old Jul 2, 2007 | 10:35 PM
blackhat620's Avatar
blackhat620
It is just coincidence, many people run staight pipe without any problems.
The P0401 Code is specifically a sticking EGR valve by definition.
P0401: "Exhaust Gas Recirculation Flow Insufficient Detected; EGR Valve Position does not match desired, limits based on engine speed / load.
EGR Valve stuck or sticking - EGR Valve Position Sensor Bias - EP Sensor bias."
Also with the latest flash the EP sensor is turned off and no longer used.
Sounds like you need to clean or replace the EGR valve.
