E4OD trans problem
Old Jun 29, 2007 | 12:51 PM
droppedf100's Avatar
droppedf100
E4OD trans problem
I have a 96 f150 with a 302/E4OD and the trans seems to lose the electronic signal and the od light flashes. When this happens it shifts really hard at 2500-3000rpm and the convereter lock-up is affected. It also downshifts into first hard when stopping. It goes away and comes back on occasion but recently it has been very often.
Also the speedometer still works when this happens as does the odometer.
Old Jun 29, 2007 | 01:24 PM
cbelt3's Avatar
cbelt3
I had this problem a year ago I changed the speed sensor on the rear axel. that seemed to stop the hard shifting up shift and down shift as for my od light its never worked
Old Jun 29, 2007 | 01:53 PM
quicklook2's Avatar
quicklook2
read codes.
you can replace od light switch.
or the wires need resoldering.
Old Nov 8, 2007 | 12:23 AM
droppedf100
Talking
I found out my problem. It ended up being the speedometer itself. I swapped it out of another 96 and I havent had the problem since in 6000 miles.
