Computer Chips & Tuners
Ken
Old Sep 25, 2002 | 11:00 AM
97ExplorerV8AWD's Avatar
97ExplorerV8AWD
Ken
My ECM code is XDT2... what can features can I get from a diablo?
thanks in advance
Old Sep 26, 2002 | 02:55 PM
FTE Ken's Avatar
FTE Ken
Ken
From either a Diablo or a Superchips, more horse power, more torque, and a quicker, firmer shift. Other things can be custom modified for changes to your vehicle for a custom fee. See motorhaven.autoanything.com/Web_store/Html/chipfaq.html
Here's the part I put there about the Diablo:
Once installed, it overrides the original ROM in the ECU with its own, which we program. The chip remaps the ignition curves and advances timing curves by anywhere from 3-8 degrees, depending on load and rpm. The fuel curve is remapped by an average of 2% leaner than the original curve, mainly because the factory settings are set rich in order to cool the catalytic converter for low-grade fuel. High octane gasoline burns more complete and cooler than lower-grade gasoline. We trim the excess fuel based on high octane gasoline and by doing so we create a better air/fuel ratio, which equals more power, i.e. more efficient running engine.
For electronic transmissions (most 94-up cars and trucks), the line pressure is increased, firming up shifts. Shift points are optimized, controlled by mph at partial throttle and by rpm at wide-open throttle. The shift delay is reduced, allowing gears to engage quicker and torque convertor lockup parameters are adjusted.
The Diablo tends to have a little more HP than the Superchips. Diablo also has the Delta chip which can have up to 3 settings. If California CARB certification is your concern then the Superchips is the way to go.
Old Sep 29, 2002 | 12:27 AM
lvmoose007's Avatar
lvmoose007
Ken
Mar 9, 2016 12:40 PM
David Fulmer
Nov 8, 2015 03:13 PM
spdmpo
Feb 19, 2010 07:28 PM
DeGideo
1978 - 1996 Big Bronco
Mar 25, 2002 11:09 AM
Franklin2
May 4, 2001 05:55 PM
