I was reading that the delta has different modes. If you put it back in stock mode would it meet emission standards? And lastly would I be able go get one for my 95 F-150 4x4? I can get the code later if I know it would work on my truck. Thanks in advance
Almost always a vehicle will actually run cleaner with a chip. Having said that, in the state of California you need CARB certification numbers with aftermarket products and Diablo doesn't have that (yet). If you flip it back to stock it will run as clean as it did before so if it passed emissions before it will again, and it would still probably pass them even if you didn't put it into stock.
