1978 - 1996 Big Bronco
Steering in a bind
Old May 4, 2001 | 10:30 PM
Boss_358's Avatar
Boss_358
Steering in a bind
The steering on my girlfreinds 82 bronco binds sometimes for no reason at all. Driving straight down the road the steering will all of a sudden pull to one side. When you steer the other way to correct it after a little bit it will let loose and send you the direction you were offsetting your steering wheel to. We have replaced the gearbox thinking that was the problem. It seems to have slowed down but the problem still exists. Now i'm thinking linkage or possibly balljoints could be getting old and rusty, or something. Anybody else had this problem or have any ideas?
Old May 5, 2001 | 12:20 PM
bjw's Avatar
bjw
Steering in a bind
more than likely your correct.
my bet it's the ball joints or joint, and you can jack up the whole front end, and let someone move the steering back and forth while you lay down there and watch, and you can also take the wheel by hand, and move it back and forth,and see which one is grabing.
grease may work but more than likely it want.
good luck,
Old May 8, 2001 | 07:51 PM
bgblktruk's Avatar
bgblktruk
Steering in a bind
Well I'm going to have to guess ball joints also but if you find that those are o.k. I had a similar sounding problem except it happened when I would initiate a turn. I ended up changing the radius arm bushing. Those are the only things I got good luck. let us know how it plays out.
Old May 10, 2001 | 05:57 AM
AlM's Avatar
AlM
Steering in a bind
Scoob5555
May 11, 2021 09:33 PM
Kiwibrett
Australia Chapter
Jan 16, 2017 03:12 PM
79f250ranger
Aug 9, 2016 02:08 PM
Platinum08
Jun 10, 2015 05:37 PM
007bronco
Mar 24, 2004 12:42 PM
