1978 - 1996 Big Bronco
Tailgate question
Old Nov 18, 2001 | 02:22 PM
vooter61's Avatar
vooter61
Tailgate question
Hey, everyone:
I have an '88 full-size Bronco, and the bottom of the tailgate is basically shot through with rust (this seems to be a common problem with these trucks). The power window works fine (using either the key or the dashboard switch), as does the spare tire rack (although its connection to the tailgate appears to be getting a little weak).
I'll probably end up just replacing the tailgate, but I've seen "shell only" ads and was wondering if that might be the smarter way to go, assuming that all of the inner workings of the tailgate are okay.
Any thoughts?
Thanks--
Gary
Old Nov 18, 2001 | 04:43 PM
restorit's Avatar
restorit
Tailgate question
Replacing the shell should be fine. You can have it painted to match your old gate, and in a weekend swap the inner glass, hinges, regulator, etc. over to it and install it on your truck. I know there is a considerable price difference between the Ford shell and the aftermarket ones. I would imagine the aftermarket shells may be made of thinner-guaged material, and may not fit as well, but there may be some quality ones out there, also, which would be less expensive than a factory replacement.
Old Nov 18, 2001 | 08:01 PM
vooter61's Avatar
vooter61
Post Tailgate question
Thanks for the help!
Gary
Old Nov 19, 2001 | 09:49 AM
tamarackstyle's Avatar
tamarackstyle
Tailgate question
I used an aftermarket from jc whitney. everything bolted up fine and only took a couple of hours. check the condition of the access panel on the inside. mine was shot! the only place I have found them is bronco graveyard (diamond tread)
Old Nov 19, 2001 | 04:28 PM
heybrent's Avatar
heybrent
Tailgate question
Aftermarket tailgates are much thinner and will dent a lot easier than the original tailgate. I have two tailgates which I am selling but shipping I have found is OUTRAGEOUS for the 95 lbs and size. Email me if you want to ask me anything else.
Brent
p.s. These shells are 80-86 versions but they will fit all the newer models and have no rust on them.
Old Nov 19, 2001 | 07:32 PM
AlM's Avatar
AlM
Tailgate question
look here at Dustin's excellent t gate replacement article w/pics!
http://users.superford.org/ylobronc/tailgate/tailgate.html
he used certifit:
http://www.certifit.com/index.html
Old Nov 20, 2001 | 10:16 PM
vooter61's Avatar
vooter61
AIM:
Thanks for the great site! It was exactly what I was looking for....
Gary
Old Nov 21, 2001 | 08:03 AM
CrmScntst's Avatar
CrmScntst
Tailgate question
1985 Bronco
Jun 15, 2016 01:41 PM
boss429kiwi
Oct 9, 2007 10:48 AM
Kanuck
Bed Covers, Tonneau covers, Toppers/Canopies & Bed liners
Oct 9, 2007 06:08 AM
texcan
Mar 25, 2007 07:24 AM
1961UNI
Mar 26, 2005 09:04 PM
