Smells like fuel
Old 04-15-2007, 10:56 PM
Broken40's Avatar
Broken40
Broken40 is offline
Smells like fuel
This white box thing came out of my brothers 79 f150 custom and i have no idea what it is, when i took the black cap off the top off the box it smelled like gas, when i shook it to see if something was in it, it sounded like there was sand in it. The black peice at the top has 3 vaccum stems comeing from it and only 1 of them has a line going to it. The 1 line that is there goes down the frame and to the gas tank.....can someone help.
Old 04-15-2007, 11:00 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
That is the vapor recovery cannister. It is full of carbon. It keeps the whole vehicle from smelling like fuel. Put it back on the truck and make sure it is working properly.
Old 04-15-2007, 11:02 PM
bigun72's Avatar
bigun72
bigun72 is offline
my 72 had one of it and i broke it ....do you have to have them on there ?
Old 04-15-2007, 11:10 PM
Torque1st's Avatar
Torque1st
Posting Legend
It can get stinky if the system does not work right and if you plug lines other problems can happen. The cannister does not hurt anything, recovers some of your fuel, so why not keep it?
Old 04-15-2007, 11:16 PM
bigun72's Avatar
bigun72
bigun72 is offline
i guess ill have to go get another at the junkyard , it fell off and then i run over it lol ... probly cost like $5 at the yard ..
Old 04-15-2007, 11:33 PM
Mil1ion's Avatar
Mil1ion
Mil1ion is offline
Here is what it is part of.
Old 04-16-2007, 12:23 AM
Torque1st's Avatar
Torque1st
Posting Legend
That diagram only shows part of the system.
If they charge you $5 find another junkyard!!! Just get the right one. Some of them did not work with manifold vacuum and used a hose to the aircleaner instead. That type was only used a short while. Apparently it did not work well for some reason.
Old 04-16-2007, 02:39 AM
NumberDummy's Avatar
NumberDummy
NumberDummy is offline
Ford Parts Specialist
1971/72 F Series charcoal cannister is the same one as all the 1971/72 cars used. It's also the same as 1971/72 Bronco & Econoline.
Old 04-16-2007, 09:24 AM
Broken40's Avatar
Broken40
Broken40 is offline
Well, i thought it was worthless, i did put it back on but i still have 1 hose that is floating around coming out of the box but i have no idea where it goes, any ideas.
Old 04-16-2007, 03:41 PM
Alvin in AZ's Avatar
Alvin in AZ
Alvin in AZ is offline
That's the gas tank danggit! :/
He's prob'ly gonna want that stinky thing. ;)
Alvin in AZ
Old 04-16-2007, 07:47 PM
F250Moneypit's Avatar
F250Moneypit
F250Moneypit is offline
I guess that's why mine smells like a gas station when I park it at night, previous owner removed all that stuff.
Old 04-16-2007, 09:08 PM
Torque1st's Avatar
Torque1st
Posting Legend
-That's right!
Maybe Dennis has a picture of the rest of the system where it hooks to the engine on his website. Also the vacuum diagrams on the AutoZone site may have them.
One way to make them work that I used on one of my vehicles is to find the outlet hose and connect it to that extra nipple on the PCV valve. I used a 1/4" long piece of aluminum rod that fit inside the hose with a 1/16" drilled orifice in it to limit the flow. I installed the orifice in a short length of hose with a coupling right near the valve so someone might give it a second look before replacing it.
Is that top white port on the top of the box plugged? That was where the old large tube to the aircleaner was connected. If it is not plugged you may want to get a cap to put over it.
The outlet hose is probably the small one below the diaphragm valve. You may have to connect the top port to your vacuum tee to open the vent valve.
Old 04-16-2007, 09:18 PM
Alvin in AZ
I guess that's why mine smells like a gas station when I park it at night...
If so, that's because it's not a Ford pickup you have there, it's a leaky old Volkswagen. :) If there ever were such a thing as a "fix or repair daily"... :/
Alvin in AZ
burnet44
1983 - 2012 Ranger & B-Series
12-29-2014 03:45 PM
7Gen
11-04-2013 09:32 PM
highboy
08-05-2007 07:30 PM
Frank Kistner Sr.
Aerostar
01-10-2004 07:02 AM
sears27
11-05-2000 07:18 PM
Quick Reply: Smells like fuel
