1978 - 1996 Big Bronco
Stubborn O2 sensor codes!
Old Feb 13, 2002 | 11:19 PM
broncoman2000's Avatar
broncoman2000
I own a 96 Bronco 351. I ran a diagnostic scanner and came up with 5 codes all refering to O2 SENSOR HEATER CIRCUIT MALFUNCTION for all 3 oxygen sensors and SYSTEM TOO LEAN for front and back sensors. I can't seem to pinpoint the problem. I have replaced all 3 O2 sensors,checked all the wiring and connections to the O2 sensors, checked all fuses and sparkplugs, replaced corroded + battery cable
($130 special order from dealership),and finally the PCV valve was replaced and still no luck clearing those codes. After erasing these codes they only comeback after 3 start-ups, and won't pop up after 1 start-up and 30 min. of driving. If anyone could give me some tips, hints, or info. concerning this it would be appreciated greatly. Thanks
Greatly Appreciated,
Robert
Old Feb 14, 2002 | 01:00 AM
Franklin2's Avatar
Franklin2
See if you have a grey/yellow wire and a black wire at the oxygen sensor. The grey/yellow is the 12 volt feed for the heater on the sensor. The blk is the ground. Check across these two wires. If no 12 volt, check from the grey/yellow to a shiny metal place that is known to be a good ground. If you have 12 volt, you know there must be a bad ground where the blk wire connects. If you still don't have 12 volts, the diagram shows a fusible link feeding this circuit. The color of the wire is shown to be grey/yellow on both sides of the fusible link. I can't seem to determine where this fusible link would be located, but a good guess would be off the EEC power relay. See if you have a relay box on the fender somewhere that has a bunch of these fusible links coming out of it. It's supposed to be a blue 20 guage fusible link. It may be burnt open.
Old Feb 14, 2002 | 08:22 AM
jdgreen's Avatar
jdgreen
Old Oct 26, 2005 | 05:31 PM
flipsidem's Avatar
flipsidem
Broncoman,
Did you ever figure this out? I have the same Bronco with the same problem.
Thanks,
Martin
Old Oct 26, 2005 | 06:08 PM
IB Tim's Avatar
IB Tim
FTE Leadership Emeritus
WOW...very old thread, no matter Welcome to FTE.
Old Oct 26, 2005 | 06:13 PM
flipsidem's Avatar
flipsidem
It's driving me crazy.
Thanks for the welcome!
-Martin
Old Oct 26, 2005 | 06:40 PM
IB Tim's Avatar
IB Tim
Post a new thread, tell your problems and we'll see what pops up.
