Computer Chips & Tuners
How Bad Is It...?
Old 03-21-2007, 03:15 PM
drj777's Avatar
drj777
drj777 is offline
Unhappy How Bad Is It...?
...i just installed my first program...and thought i had removed the fuel pump fuse (@ first i did - and then i mistakenly put it back)
painfully - i realized this just before the program was finished installing.
however - i never started the car...i returned it to the stock program and then started the truck.
seemed fine.
then - i removed the fuse (AGAIN) and re-installed the tuning program - then started the truck.
seems fine.
so im an idiot...but is my truck gonna be ok?
drj
Old 03-22-2007, 06:07 PM
ReAX's Avatar
ReAX
ReAX is offline
I haven't understood why superchips wants you to do that, but my tuner doesn't require it. If it is running, you should be fine.
Old 04-04-2007, 11:45 AM
Troyer Performance's Avatar
Troyer Performance
Troyer Performance is offline
Former Vendor
You should be OK.
The reason this is required is in case a fuel injector leaks, as the entire time you are flashing the PCM the fuel pump is running flat out on vehicles with return-style fuel systems,s which the F-150 used up thru and including the 2003 model year.
Basically, any vehicle that has a return style fuel system should have the fuel pump fuse removed any time the PCM is being flashed to prevent the possibility of an injector leaking fuel and thus filling one (or more) cylinders with fuel, and as a result, bending a connecting rod or having an explosion when you go to start it.
In this case, the vehicle started up just fine, so he got lucky and is OK. Just remember to pull that fuel pump fuse from now on, OK?
Good luck!
Old 04-04-2007, 04:34 PM
drj777's Avatar
drj777
drj777 is offline
Talking
i may be slow and often find that my public school education has failed me...however, i CAN assure you that i WONT forget that dang fuse again!!
thanks for the help.
drj
drj777
02-04-2011 10:23 AM
drj777
Offroad & 4x4
07-18-2007 05:28 AM
drj777
Offroad & 4x4
07-11-2007 11:28 PM
drj777
Appearance & Dress-Up
06-11-2007 04:10 PM
drj777
Offroad & 4x4
17
04-30-2007 07:50 AM
Quick Reply: How Bad Is It...?
