ABS Sensor?
Old Mar 30, 2007 | 07:04 PM
93f1505.0L's Avatar
93f1505.0L
ABS Sensor?
I have a 93 f150 5.0L 2wd reg cab long bed. There a a sensor that is bad on a brake line block. I'm gussing that it is for the ABS. A while back my cc stop working then about 4 or 5 months after that I kept blowing my brake light fuse and it was that sensor that was doing it. I would press the brake and the sensor would smoke and then the fuse blew. The conector seemed messed up so I just took the wires out and electrical taped them apart. THe ABS seems to still work. I can feel it in the pedal sometime but it doesnt seem as fast as it used to be. Also the sensor is leaking and I think that had more to do with it than anything. I have no idea what it is called so if anyone knows can you please tell me. I am selling the truck and want to make sure everything is right before I do.
Thanks
John
Old Mar 31, 2007 | 07:29 AM
EPNCSU2006's Avatar
EPNCSU2006
It's not mounted to the brake master cylinder under the hood, is it? If so, it's subject to a recall for the internal diaphragm rupturing and burning down the truck.
Old Mar 31, 2007 | 10:27 PM
93f1505.0L's Avatar
93f1505.0L
No Its not. It kinda looks like the one you are talking about but I think they changed from mine the the one on the master cylinder in 94 becuase all the ones Ive seen are on the master cylinder and they have been 94 and up. Ill try to get some pics tomarrow.
Thanks
John
