Code P0299 Turbo Underboost
Old Mar 27, 2007 | 07:57 PM
tiredlr's Avatar
tiredlr
Talking Code P0299 Turbo Underboost
Have A Code P0299 Turbo Underboost. No Lights On, Just Some Issues Like Excessive Lag, Stumbles Out Of A Corner. Wondering If Someone Can Tell Me If This Is A Sensor Issue Or If The Turbo Has To Be Replaced. It's Still Under Warranty I Just Hate The Thot Of Removing The A/m Goodies,and Even Worse.....being With Out My S/d
Old Mar 28, 2007 | 07:58 PM
Kep4's Avatar
Kep4
Jäger
You would need to load the stock file from the SCT because they may want to 'flash' the truck while it's in. I wouldn't worry about the exhaust at all. The water/meth injection though, they could blame turbo issues on that whether valid or not.
My main concern would be confirming the service department where you take your truck has 6.0 Certified Technicians. If they don't then find one that does or you'll definitely regret it.
Do you have the stock intake on the truck?
Old Mar 28, 2007 | 11:12 PM
tiredlr's Avatar
tiredlr
i do have a cold air intake AFE progaurd7, but I'm still inpossesion of the stock unit, for such instances
Old Mar 28, 2007 | 11:16 PM
tiredlr's Avatar
tiredlr
Yes i do agree about the certified techs. I had it to 2 different dealerships when my head gaskets went. i finally bit the bullet and put in the ARP headstuds and Hypermax gaskets, since i'm sure my mods were partially responsible.
Old Mar 29, 2007 | 06:58 AM
BowTieHatr's Avatar
BowTieHatr
well i can tell you it is a sensor issue or that the turbo needs replacing, and probably still be wrong. cetain pids will need to be watched on a test drive to pinpoint the issue. it could even be a ypipe issue or a boost leak. good luck getting it fixed.
Old Mar 29, 2007 | 08:08 AM
CanadaGuy's Avatar
CanadaGuy
Why remove the A/m Goodies?
Old Mar 29, 2007 | 08:10 AM
Lonewolftx's Avatar
Lonewolftx
Unhappy Me too . . .
I got the same code yesterday. Showed up when I changed tune back to stock. No boost, sluggish, poor shifting, etc. Like the turbo isn't really working.
Going in on Monday.
Old Mar 30, 2007 | 02:21 PM
tiredlr's Avatar
tiredlr
Wink
i DONT THINK THE SERVICE ADVISOR WOULD BE AMUSED WHEN HE SAW MY COLD AIR INTAKE,AND THE WATER LINE RUNNING INTO THE BOOST TUBE. *WINK*
Old Mar 30, 2007 | 02:54 PM
tiredlr's Avatar
tiredlr
[QUOTE=BowTieHatr]well i can tell you it is a sensor issue or that the turbo needs replacing, and probably still be wrong. cetain pids will need to be watched on a test drive to pinpoint the issue. it could even be a ypipe issue or a boost leak. good luck getting it fixed.[/QUOTE
I DID CLEAR THE KAM AND RAN THE TURBO THRU THE VGT RELEARNING SYSTEM, AND IT DID SEEM TO CHANGE THE WAY THE TRUCK RAN FOR A SHORT TIME. DONT KNOW IF THAT MIGHT HELP NARROW IT DOWN?
Old Mar 31, 2007 | 11:35 AM
CanadaGuy's Avatar
CanadaGuy
Why not?? I find it quite amusing when I'm losing my shirt doing a warranty headgasket job caused by mods...
Old Apr 2, 2007 | 08:01 PM
tiredlr's Avatar
tiredlr
Are you equally amused when you lose your shirt doing the legitimate warranty work on these often problematic engines. I'm not amused when Ford denies a warranty claim, blaiming turbo, injector, head gasket failures on after market mods either. But all that aside, I for 1 did have my headstuds, and headgaskets replaced outa pocket. OUCH!
Old Apr 3, 2007 | 01:52 PM
Beerstalker's Avatar
Beerstalker
I was kind of wondering how he was losing money by doing the work and getting paid by Ford. I can see how Ford is losing money but not the service department.
Old Apr 3, 2007 | 02:13 PM
Lonewolftx's Avatar
Lonewolftx
Smile Repaired . . .
Well I had mine in for this yesterday and they replaced the turbo and turbo oil drain tube. It had 19,241 miles on it.
Old Apr 3, 2007 | 08:12 PM
tiredlr's Avatar
tiredlr
The hourly time a mfg. pays a tech to do warranty work is much less than if they were actually selling the job, or (flat rate time). I think FORD pays somewhere around 13 hours on a head gasket job, and it takes more like 18 to 20
Old Apr 17, 2007 | 10:54 PM
GR8TWHITE's Avatar
GR8TWHITE
TIREDLR I had this same code come up on my truck, I took off the edge progammer and placed everything to stock and reset, drove truck for a few miles, no check engine light yet, But I did notice the Egr test on my OBD11 tool was always on. Any updates on what fixed yours? Any info would be grateful.
