water vs coolant in 6.0
Would it run colder with water or should I stick with coolant ,
I know the reason my coolant is boiling ,the egr cooler,but until I put on a egr delete up pipe my engine is going to run hot .
So i'm thinking about just running water with water wetter ,but if the stock coolant is still good after boiling I'll stay with it.
You need to switch to Evans waterless coolant, much better than standard antifreeze and also better than water.
www.evanscooling.com/main1.htm
Hope this helps
Hope this helps
EconolineFan
22
06-25-2019 04:18 PM
bevisbeck2
08-22-2016 09:18 AM
mfp4073
1983 - 2012 Ranger & B-Series
03-07-2013 07:59 PM
