mine (virtually the same as my mom's 99 expo) has a menu button you cycle through and one of those options is clock. then just hit the select buttons to get it right. i think it said "select hour" then "select mins"
Can anyone tell me how to adjust the clock on my 2000 Ranger?
thanks Rich_H
I'm only laughing because it took me a year and a half to figure it out on my GMC. And when the time change happened again 6 mo. later, I forgot. It was one of those 'frig with it till it happens' things in the first place. Try hitting the 'SET' button, but instead of hitting a station preset key, turn/press the tuner **** button.
If so, then on the face of the radio/cd, there should be a clock button marked (CLK).
If you push & hold it in, you can then use the "seek" <rocker > arrows to toggle the hour setting up or down, same for the "tune" <rocker> to toggle the minutes seting, up or down.
If you have other than a Ford product, it would be helpful to know the brand.
