Stalling
Old Mar 19, 2007 | 05:46 PM
Truck Issues's Avatar
Truck Issues
Red face Stalling
Hi,
I own a 98 Ford Explorer, 143000 miles which started to stall as I come to a stop. Once this happens, the truck starts easily in Park and Neutral and as soon as I place it in Reverse or Drive it immediately stalls again. I purchased an OBDII Scanner which shows Errors P0174 and P0171. Apparently, I've been driving with a spark plug that was loose as well as the wire connected to it for quite some time. Is it possible for the catalytic converter to be bad? There is some black smoke ring at the end of the tail pipe. The fuel filter has never been changed and am not sure if this would cause to stall or if it truly is a bad O2 sensor(s) (4 Sensors). The error is Bank 1 and Bank 2 too lean. The tranny was replaced over a year ago, and not sure if it's gone bad again, the stalling feels like when you come to a stop while driving a stick and you don't down shift to 1st gear, it stalls. Thanks for helping!
Old Mar 20, 2007 | 05:11 AM
marragtop's Avatar
marragtop
Start by replacing all the plugs and wires. Also check for vacuum leaks.
Old Mar 20, 2007 | 08:34 AM
taz1y's Avatar
taz1y
also could be your mass air sensor, would hurt to change your fuel fiter too
Old Mar 21, 2007 | 09:51 PM
Truck Issues
Thank you for your valuable input and Keep Trucking!
Old Mar 22, 2007 | 05:33 PM
marragtop's Avatar
marragtop
If you are going to do the plugs and wires, go thru the wheel wells. It's much easier.
