Electrical Issue
Old Mar 5, 2007 | 11:28 PM
Hawk180's Avatar
Hawk180
Electrical Issue
This is not really a problem, but an observation that might help someone. I just changed the starter solenoid on my 94 F150. I was amazed at how much better all the electrical system worked; from the lights to the ignition system. I had never really thought much about it, but I guess most of the electrics do run through that circuit where the large wire terminals attach to the solenoid. By cleaning them when I changed them, it helped the rest of the electrics work on the truck better. So if anyone out there is having wierd electrical problems, try cleaning the corrosion off the terminals at the solenoid. You never know what you may fix.
