axle decoding
Old Feb 15, 2007 | 04:20 PM
adharvey2's Avatar
adharvey2
axle decoding
Does any body out there have info for decoding '62 Ford rear axles? My code is G3. Thanks.
Old Feb 15, 2007 | 04:47 PM
adharvey2's Avatar
adharvey2
The truck may possibly be a 61. VIN: C60CU220628
Thanks
Old Feb 15, 2007 | 06:34 PM
banjopicker66's Avatar
banjopicker66
It is a '62 model, made in early Oct '61.
Your rear axle is a 2 speed Eaton, 15,000 LB capacity, with 6.50 and 9.04 ratios - if the door and tag are original to the truck.
Old Feb 15, 2007 | 07:19 PM
adharvey2's Avatar
adharvey2
A thousand thanks, banjopicker!
That is good news - matches the reality on the ground (and on the paper work!). The axle is stamped 6.50. That also explains why the engine block is a C1AE instead of a C2AE. The only thing that puzzles me now is that this is not a particularly heavy 600, but it has 8 lug wheels - all the other 600s I have seen this age have "big 6" wheels.
Andrew
