Exhausting Truth, cat's or not? Muffler?
yes, i think gutting cats does increase your power and gas mileage, especially if you have 130,000 miles plus on the clock, ive done it to a 302 and my 300, made the 302 run a heck of a lot better, both these trucks had 200k + on them with STOCK converters, what i dont understand, how can the original owners not notice the decrease in fuel economy and power??????
Easily. It happens VERY slowly and over a long period of time
so the change is very incremental. Same thing with shocks.
They seem not too bad until you swap them out for a new set
and then it is "Wow! It sure rides nice now".
Ed
Also, keep in mind that modern catalysts don't really rob any power like the older ones do, unless they get clogged up, usually caused by prolonged neglect of a drivability problem or lack of maintenance. Also, even when everything goes right with them, like anything else, they evenually wear out and fail. When the catalyzing elements inside the cat deplete, then carbon builds up on the matrix, and clogs up. This causes a chain reaction. The engine runs worse, and that results in more carbon. More carbon causes more clogging, and he viscious cycle continues.
Originally Posted by ceetwarrior
Good point Argo. So would your vote be to keep the cat until failure?
I have an EFI, and I want to run a 2 1/2 in. single eshaust through a glasspack. If I remove the cats, will my mileage decrease??? I've read mixed reviews in this thread. Or, shouhd I just gut them???? I'm looking for a bit better fuel economy. I've done a complete tune-up, including fuel filter, plugs, wires, cap, rotor, K&N filter. She runs excellent, but only get 15 mpg at best driving 55. She's got a 3.08 rear with a 5 speed. Is 15 all I should expect?????? Please help with any suggestions for economy improvements. I also need to check my O2 sensor......
Duche400
Duche400
Duche400
Duche400
fuel melage 4.9
I'll give it a try. Wow, so I shouldn't use overdrive, hey?? Where I drive it, I never take her above 65. I'm a 55-58 driver. Hey Argo, another quick question...the truck has cruise, but it quit working about 5 years ago. I never had it fixed, but do you have any suggestions on what it could be??
Another thing...I see you have a traction-loc. Is it aftermarket?? I'm considering installing one...any thoughts?? I mean I really don't need 4 wheel drive, but it does get pretty slippery on these Upper Michigan roads!! I had a '76 F100 with a 300 and three-on-the-tree. It had a 3:50 posi and she gripped like no tomorrow!!! I'd like that for the '92. I've read that they're not too difficult to install (good, because I'm no mechanic).
Thanks,
duche400
Thanks,
duche400
I'll give it a try. 1)Wow, so I shouldn't use overdrive, hey?? Where I drive it, I never take her above 65. I'm a 55-58 driver.
2)Hey Argo, another quick question...the truck has cruise, but it quit working about 5 years ago. I never had it fixed, but do you have any suggestions on what it could be??
3)Another thing...I see you have a traction-loc. Is it aftermarket?? I'm considering installing one...any thoughts?? I mean I really don't need 4 wheel drive, but it does get pretty slippery on these Upper Michigan roads!! I had a '76 F100 with a 300 and three-on-the-tree. It had a 3:50 posi and she gripped like no tomorrow!!! I'd like that for the '92. I've read that they're not too difficult to install (good, because I'm no mechanic).
Thanks,
duche400
Thanks,
duche400
2)Your truck may be in danger of bursting into flames. No BS, the cruise modules on these trucks will go up, there was a big recall campaign for it. Unplug your cruise control for now, and ground the horn wire separate of the speed control. As for fixing the cruise, I'd go with an aftermarket one (Motorola has a nice one that will work off of the VSS).
3)I got an axle from the junkyard and had the Trans and Drive class at school build it with 3.08 gears and a trac-lok. I got the used trac-lok off of Ebay. I was able to keep driving the truck while the other rear got built, then I swapped the rears in a day over thanksgiving weekend. Don't try and do it yourself, it's very easy to make very expensive mistakes. It's not hard if you have the know how and the tools to do it.
#29
I'll agree that the sweet spot for a 300 involves 3.5 gears, 31ish inch tires, a 1:1 gear (or equivalent to the afore mentioned) and cruising 60-65. I consistently get 18-20 out of my truck without an overdrive.
As for exhaust sound, my favorite was a high flow cat with pipe back to just before the rear axle. It reverberates off of the bed and gives a nice low tone to it. I liked running just the cat more than running just the muffler, FWIW.
But right now i'm running a single flowmaster 40 (blew the cat) and it isn't too bad, it just gets to droning on the interstate.
Justin
Justin
#30
exhaust
I have an 86 f-150 and i just gutted out the cat and cut everything off about 3 feet behind it and slapped on a glass pack. It dont snap or cackle but it has a deep tone that will shake the doors and windows in my house. It sounds great even above 3000rpm's. It sounds like an old cummins
