Spark Plug Gap help
Old Jan 25, 2007 | 03:06 PM
Rob_1990_Bronco's Avatar
Rob_1990_Bronco
Spark Plug Gap help
I'm gonna do a tune up on my 1994 F150 6cyl .... what is the gap needed for the spark plugs? I'm using NGK.
Thanks.
Old Jan 25, 2007 | 03:43 PM
Rob_1990_Bronco
anyone please??
Old Jan 25, 2007 | 03:54 PM
jroehl's Avatar
jroehl
The I6 is the one I don't know. All the others are 0.042-0.046". There should be an emissions label or engine tuning label under the hood somewhere with the proper gap on it. I always set mine to the low end of the range--that way, as they wear, they open up and stay in range longer.
Jason
Old Jan 25, 2007 | 04:39 PM
andym's Avatar
andym
It's the same range for the 300. .042 to .046. I'd skip the NGK's, if it were my truck, and go with autolites.
Old Jan 25, 2007 | 04:48 PM
Rob_1990_Bronco
They didn't have Motorcraft at the dealer, then they didnt have autolites at the parts store, so I went with ngk which were even more expensive then the autolites.... if it starts running crappy I'll put in autolites. Thanks guys.
Old Jan 25, 2007 | 05:09 PM
quicklook2's Avatar
quicklook2
use motorcrafts.
some one in your area sells them.
and not the platinum ones, just regular old motorcraft resistor plugs.
Old Jan 26, 2007 | 09:32 AM
SR_Crewchief's Avatar
SR_Crewchief
If your running a stock ignition then the gap is .045. It should say so on the spec decal on your airbox, provided that the decal is still there.
pidaster
Nov 8, 2009 11:50 AM
limakid
Oct 24, 2005 06:32 PM
SAUKA
Electrical Systems/Wiring
Jan 14, 2004 10:43 AM
smestas
May 26, 2003 08:46 PM
bamcginty
1983 - 2012 Ranger & B-Series
Apr 19, 2003 08:11 PM
