General Automotive Discussion
Need code help 2001 Ford Taurus
Old Jan 25, 2007 | 10:16 AM
Nitramjr's Avatar
Nitramjr
My coworker has a 2001 Ford Taurus that is throwing the code P0174 which is "System Too Lean, Bank 2". A mechanic told him it was an O2 Sensor but that the car has six and wasn't sure which one. So, multi-part question.
Does the car really have six O2 sensors? Which cylinders are bank 2? Is there a better description of that this code means? Where would I start to diagnose this issue?
I am trying to help him avoid getting shafted at the local garage. Even if I can narrow it down for him would be helpful.
Thanks in advance.
Ray
Old Jan 26, 2007 | 08:17 AM
Nitramjr's Avatar
Nitramjr
Bump.
Anybody?
Old Jan 27, 2007 | 12:27 AM
Racerguy's Avatar
Racerguy
It's got 4 sensors, 2 in front of the catalytic converters and 2 behind them.
Bank 2 is the one with cylinders 4,5 and 6......the bank at the front of the engine, next to the radiator.
You could try swapping both front sensors and see if the code follows the sensor.
Check carefully for vacuum leaks too. Most leaks show up better when the engine is cold. Spray Carb-Medic carb cleaner spray or something similar at the intake manifold where it attaches to the heads, at the vacuum hoses etc. If you spray and the idle changes you've found a leak.
Old Jan 27, 2007 | 07:57 AM
Nitramjr's Avatar
Nitramjr
Thanks a bunch. I'll probably give him a hand changing the one bad one. Thankfully it is in front where it is easy to get to from under the hood. I appreciate the response.
Old Jan 30, 2007 | 05:05 PM
Nitramjr's Avatar
Nitramjr
Update. We changed the O2 sensor this morning and no change. At least it was an easy job - even at 3 in the morning and 15° out. I didn't have the code reader with me but the CEL is still on. Originally it was only throwing the P0174 code according to his mechanic.
Doing some more research, I am wondering about the MAF sensor or, as Racerguy mentioned, possible vacuum leaks.
My question now is, assuming the original mechanic was correct, would a bad MAF or vacuum leak cause only one bank to run lean?
I am checking codes for him tomorrow and putting a vacuum gauge on it as well but any advice would be appreciated. Any tricks and tips to diagnosing a bad MAF? Thanks.
Old Jan 30, 2007 | 06:02 PM
Beast12's Avatar
Beast12
Did you unhook the battery for around 30 mins or so to reset the check engine light?
-Matt
Old Jan 30, 2007 | 06:09 PM
Nitramjr's Avatar
Nitramjr
Yeah, we disconnected the battery for several hours. After work we hooked her back up and the car ran fine with no CEL. But, by the time he got back home it was acting up again.
In an attempt at being brief, I neglected to mention that the car runs great cold. There is no hesitation, sputtering, smoking, nothing. The engine is smooth as glass until it warms up. Probably should have mentioned this - sorry.
I've got a can of carb cleaner, the code reader, a vacuum gauge and some tools in the car for tomorrow. Hopefully we can get to the bottom of this - with the help of you all.
Old Jan 30, 2007 | 06:12 PM
Beast12's Avatar
Beast12
What's the carb cleaner for? I think you will want throttle body cleaner. The carb cleaner is not good for it.
-Matt
Old Jan 30, 2007 | 06:24 PM
Nitramjr's Avatar
Nitramjr
It's for looking for vacuum leaks and it is in fact throttle body cleaner. I do know better than using carb cleaner in these new fangled engines.
I am old and still say things like "carb cleaner", "record albums" and I still "dial" telephone numbers. It's that "old dog, new trick" thing.
Old Jan 30, 2007 | 06:26 PM
Beast12's Avatar
Beast12
Gotcha.
-Matt
Old Jan 31, 2007 | 06:11 AM
Nitramjr's Avatar
Nitramjr
Another update - we pulled the codes this morning and got BOTH P0171 and P0174 which indicates that both banks are running lean (and we probably didn't need to change that O2 sensor).
I am leaning toward the MAF. I don't think there are vacuum leaks since the car runs to smoothly when cold but I will check that at our morning coffee break.
Anyone have any thoughts?
Old Jan 31, 2007 | 08:35 AM
Racerguy's Avatar
Racerguy
The hose between the air filter housing and the throttle body is tight? No hoses off anywhere?
Most vacuum leaks show up more with the engine cold.
Cleaning the MAF is quick and easy to try.
If you have access to a scan tool that will read live data take a look at https://www.ford-trucks.com/tsb/full...hp?tsb=04-17-4
Old Jan 31, 2007 | 11:19 AM
Nitramjr's Avatar
Nitramjr
Here is the latest.
No apparent vacuum leaks. Throttle body looks pretty clean (sprayed it anyway), MAF looked okay (can you tell by looking?), sprayed TB cleaner all over the manifold and any other potential leak spots and got no change in the idle which was smooth as could be with the engine cold. No CEL either....
I put the vacuum gauge on the intake manifold and it's only pulling about 18.5" but it is nice and steady. The big hose I took off (back of the manifold - supplies brake booster I think) seemed loose but my gauge was in there nice and snug.
Lunch was over before we got the car warm enough to where it would start to misbehave and throw the code but when the car is cold it runs great.
Any more thoughts before I give up?
Thanks Racerguy but I don't have access to live data......yet!
Old Jan 31, 2007 | 10:39 PM
Racerguy's Avatar
Racerguy
About the only thing you can tell by looking at the MAF is whether or not it needs cleaning. Take a look at the little filament looking pieces inside and see if there is any fuzzy buildup on them. If there is spray it off with electrical contact cleaner or something like that. Don't touch them...they break easily.
18.5" of vacuum should be good.
Do you have access to a fuel pressure gauge? Checking the pressure at the fuel rail would be a good idea too.
Old Feb 1, 2007 | 07:18 PM
Nitramjr's Avatar
Nitramjr
It's always the stupid little things.....
As it turned out, or so we believe so far, the stupid little rubber elbow for the PCV valve had a leak in it. Put a piece of tape over it and so far no problems with it. We looked and looked for vacuum leaks yesterday and never found any but he found the leak last night after the engine was nice and hot. With the engine cold to warm we couldn't find a thing. Who knows, maybe as the engine got hot that rubber elbow expanded enough to leak or something. Aggravating.
He drove it to and from work today and it ran great for him. He reset the computer so I'll check codes tomorrow but it's looking good. I'm rechecking the vacuum too just for kicks - I want to see what it is without leaks.
Thanks for all the help on this. I learned a lot from ya'll.....and I'm getting lunch from my coworker but he really owes it to you folks.
