replacing guage cluster
Old 01-08-2007, 03:49 PM
cwright07's Avatar
cwright07
cwright07 is offline
hey guys i have a 2001 supercrew and im replacing my guage cluster... i got stuck taking my dash off, whats the trick? the left side where the light switch and air vent is stuck. is there a bolt holding it in i tried pulling it like the rest it just wont come off. please help!
Old 01-08-2007, 04:51 PM
MEhokie's Avatar
MEhokie
MEhokie is offline
What you have to do is take a paperclip and make kind of a hook in the end; turn the light switch to full on (pull it out if you've got foggies too) stick it in and wiggle around a bit. You should then be able to turn it 180 degrees and the whole thing should fall out. Definitely want to google it and make sure, it's been awhile since I did it in mine.
Old 01-09-2007, 04:50 PM
cwright07's Avatar
cwright07
i have taken off the **** and turned it 180 degrees and it will not come off. what do i do?
Old 01-09-2007, 07:05 PM
Wilber15's Avatar
Wilber15
Wilber15 is offline
You should be able to get that cover off without takin the light switch out. Is the dash covers off under the steering wheel? There are 2 bolts on the very bottom of the dash panel that encircles the IP cluster, so u need to get the lower kick panel off for that. I haven't done one of these in a while, but I did just have one out of a 2000 Ranger today at work and I believe they were similar. You may beed to remove the radio bezel too to get more room to move around.....
