2001 F 150
You have not given enough information.
Is it a super cab, screw, reg cab, 4x2, 4x4 etc.?
Tire sizes also enters into the mix at some points. 16 or 17"
What rear gear?
The max gross towing weights ranges from 10,000 to 11,500 lbs over all the combinations.
Over the same range, the seperate towing weights range from 5800 to 6900 lbs.
The 5.4L motor makes a big difference on these max weights per model.
All this assumes an automatic transmission.
What rear gear?
saleen5.8
15
11-07-2013 03:21 PM
calidogj14
2009 - 2014 F150
03-13-2010 06:42 AM
momdawg
Other; Brakes, Electrical, Hitches, Weight Distribution & CDL Discussion
11-25-2006 11:34 AM
