7.3L oil leak?? look here
Originally Posted by winn9524
Redsundevil,
how much oil can I expect to come out of the plug as it looks like I have the same problem? Will it be easier to wait for an oil change?
'01 Supercab 7.3PSD Dually XLT 121K
I had a little less than a cup worth of oil come out when I pulled mine, but I'd imagine that could change depending on how recently you've driven the truck, not sure exactly. Luckily I had stuffed a large quantity of rags down in the intake valley before pulling the plug, which helped soak up the majority.
As for waiting for an oil change....my leak was bad enough that it was going to change the oil itself in about 20 miles of driving, so waiting wasn't an option. I suppose you could wait if the leak is slow, just depends on how much it bothers you I guess.
Just a reminder, I didn't have to top-off the HPOP to fix the rough-running condition, I just drove it a couple miles, but it is an option if you want to do it.
thanks for the oil leak repair
After reading the posts, I have deceided I too can "fix" the leak. The last problem was with a fuel leak thanks to the new fuel being forced on us all. Fuel leak was taken care of as the oil leak will be soon.Thanks to all on the FTE for the advice and how to's I will save enough money on repair bills to pay for this computer....LOL
hi everyone,
I am new to this site and new to owning a diesel. I recently noticed that my 03 7.3 PSD was leaking oil onto the pavement. I inspected under the hood and found there to be a puddle of oil underneath the fuel bowl. I have read a fair amount of the seals on the high pressure oil pump and was wondering if anyone could offer a detailed procedure and perhaps a diagram or two of potential problem areas.
thanks,
Drew
thanks,
Drew
Just replaced the "do not remove plug" O ring. The O ring was blown out around the plug and the plug itself was easily removed with a wrench.
Picked up a pump O ring kit at International for a 6 cylinder,had the correct O ring in it.
Cleaned threads, loc-tite green and re-installed.
No problems since.
Ford or International pump rebuild kits for the 7.3 do not include this O ring.
No problems since.
I am FIRMLY convinced that the LocTite is doing the sealing job for these plugs, not the o-rings. Both male and female threads have to be spotlessly clean and free from ANY oil residue (I used a lot of Q-tips and brake cleaner) for the LocTite to really seal perfectly.
I'm going on two years of having a Buna (not Buna-N) o-ring and incorrect (blue) LocTite in mine with no leaks.
Sorry, guys, I had to "Micky-Mouse" it one Saturday for a mandatory trip on a Sunday, and it's never leaked since. That was almost two years ago.
The correct o-rings and LocTite ride around in my center console, just in case...
I'll stick to my guns about the o-rings not really being what seals.
Pop
Pop
#29
Question about this fix...
I've had a steady oil leak for over a year, the service manager at my local stealership keeps saying, "it's a pressure type leak because of the volume of oil that is leaking, and the fact it only happens if the truck is running. If it were a rear main seal, it would just leak the same all the time." He wants to pull the tranny to investgate further, but what is hiding there to look at besides a rear main?
If the valley is totally dry, and it's not a pedestal leak, can any oil come from the HPOP? Any other spots I should be looking at?
Thanks in advance for the assistance, I want to solve this one!
#30
Hello all.
I've got a 93 F350 7.3L non turbo. I noticed some oil leaks the past few weeks so I changed the oil and replaced broken seal on drain plug thinking that would fix it. I live in San Antonio Tx. Never gets cold here. Last night it got in the low teens. Finally got it started and noticed it was really bleeding from the oil filter housing close to the front. Had to take the truck so I grab 4 Gals of oil and headed out. Got to work and check. Not bleeding just a few drips. Let it set and checked oil. Plenty of oil on dipstick. I’ve read previous posting. Seen some diagrams none of which looks like what I’ve got unless it is the front part that attaches to the tube (about 2 1/5 in dia.) that connects to filter. It looked like it was leaking where the “tube” connects to the front bracket assembly. HELP please.
