need some good instructions...
Old 01-05-2007, 04:21 PM
jumper350's Avatar
jumper350
jumper350 is offline
i am taking out my powerstroke engine, rings went bad @ 300,000 miles and need a good amount of instruction on how to take it out.... its a 95 f350 with an automatic 4x4. any advice would help!! i am swapping out the block for a remanufactured one and then installing it. thank you!!
Old 01-05-2007, 05:13 PM
1997F-350's Avatar
1997F-350
1997F-350 is offline
pretty sure dzljim.com has a good write up.
Old 01-05-2007, 05:15 PM
1997F-350's Avatar
1997F-350
are you seeing blue smoke? is that what leads you to believe its the rings??? please post what your problems are first. maybe just some injector orings. wouldnt that suck if you put your heads onto that new block and had the same problem?
Old 01-05-2007, 06:40 PM
jumper350's Avatar
jumper350
ya, took it in had the compression test all that stuff, oil coming out of the exhaust, after first thats what i thought it was but decided to take it in and they ran all there test and crap. it was coming out of the oil filler cap and the intake also hehe. sucks but thanks for the info, appreciate it!!
