Big block heads on a small block
here's a Clevor I'm building for my falcon with 71 351C heads.
http://www.topham.kicks-***.net/Clevor/index.htm
got the heads done should be together soon.
Edelbrock now sells 351C aluminum heads on a 302. They are a 4V head (smaller combustion chambers, I would not reccomend this swap with the 2V heads, chambers are too big to be efficient), and the comes with a the deck plugs to re-direct the coolant. part #61629
http://www.edelbrock.com/automotive_..._sb_clev.shtml
I would rather build a 351C, but considering they are hard to find and parts are more ready available for the windsor block, you cant go wrong. I would like to see someone build this for their mustang with EFI. I can imagine the power it would make.
