Tire size, rear end, and motors
Old 09-16-2001, 05:25 PM
darkman's Avatar
darkman
darkman is offline
Old 12-29-2001, 04:44 PM
1953Man's Avatar
1953Man
1953Man is offline
I am putting a 302 in my 1953 F100 and someone told me a 3.73 would work, but I am running 205/50/15 tires now. Is it gonna make a different with the tires when I put the 3.73 in?
Old 12-29-2001, 07:01 PM
Franklin2's Avatar
Franklin2
Franklin2 is online now
Received 1,786 Likes on 1,441 Posts
If you have the original rear, It should be approx 3.90 to 1, so 3.73 is not going to be a dramatic difference.
Old 01-02-2002, 07:01 AM
ranger pat's Avatar
ranger pat
ranger pat is offline
Here is the formula I used.
MPH X Gear Ratio X 336 = RPM/Tire Diameter
Example:
70 MPH x 3.50 gear ratio x 336 = 87729/Tire Diameter
With a 27" tire diameter, this works out to 3048 RPM
You can adjust tire diameter and gear ratio to get the
RPM you want to cruise at. If you end up with an overdrive transmission, factor .67 or final drive ratio into the
formula: MPH x Gear Ratio X Final Drive Ratio X 336 = RPM/Tire Dia.
