tachometer
Old Nov 30, 2006 | 02:25 PM
oscar_007's Avatar
oscar_007
tachometer
My 1969 F-250 with a 390 doesn't have an tachometer and I want to put one in because it is geared very lowly. It has a 3 speed tranny with 4.10 gears in the rear end so the rpms are way up there going down the highway. I put one on a chevy pickup before and it was very easy because it just pluged it into a certain spot on the distrubuter (very simple). Is this the same on this because I can't find anywhere on the distributer where it plugs into?
Thanks
Old Nov 30, 2006 | 02:37 PM
FalconStng's Avatar
FalconStng
The tach signal wire goes to the negative lead connection on the coil. The signal wire is usually green on the aftermarket gauges.
Good Luck
Tracy
Old Nov 30, 2006 | 02:38 PM
Redmanbob's Avatar
Redmanbob
maybe a governer would be better ?
Old Nov 30, 2006 | 02:56 PM
mswift's Avatar
mswift
I had a governor once. It was when I was about 4 years old and my dad thought it would be best to have one on my little 70cc 3 wheeler. Soon as I started realizing this, I fixed that damn problem.
Actually, I hear ya oscar_007, I've got a '75 highboy with 4.10s and that thing revs high going down the freeway. I just keep her at 60-65. I might be a little late getting there, but I ain't in no hurry.... I might end up doing the tach thing too. Just a nice little one that mounts on the steering column is what I'm looking to get.
Old Nov 30, 2006 | 05:45 PM
1975Ford's Avatar
1975Ford
I installed the tach wire to the negative side of coil as was mentioned. My tach works good.
I hear both of you, my 1975 F250 hi boy does the same.
Old Nov 30, 2006 | 08:47 PM
krewat's Avatar
krewat
FTE Leadership Emeritus
Yeah, the 4.10's in the Highboys are kinda high. With 33" BFG's, mine wasn't TOO bad...
Hmm... what speed is that when you hit 6000 RPM's in 4th gear?
Just being sarcastic.
An easy way to change gearing is ... change the tire diameter.
Old Nov 30, 2006 | 08:48 PM
oscar_007's Avatar
oscar_007
thanks and i was thinking of getting the kind that goes on the steering column
Old Nov 30, 2006 | 08:58 PM
"Beemer Nut"'s Avatar
"Beemer Nut"
Without tire growth on 33" tires @ 6K will get ya 143+ mph.
I've been to 5,400 with 32.5" tires at 5,400 for 127 mph in the CS.
Old Dec 1, 2006 | 12:11 AM
mswift's Avatar
mswift
I've got a question, y'all can prolly answer.....
Krewat got me thinking when he mentioned 4th gear. My truck is a '75 Explorer Highboy, 4.10 and a factory C6. With that in mind, what would swapping out to a 4 speed do? I'm not going to do it, as this is my only automatic rig, but are the ratios the same. Meaning being in 4th gear cruising down the freeway at 3000RPM, as opposed to being in "Drive" cruising down the freeway at 3000RPM.
Thanks...
Mike
Old Dec 1, 2006 | 12:47 AM
"Beemer Nut"
With all things being equal besides transmissions the auto will have torque converter slippage I would guess app 300 rpm's, more under heavy throttle and higher mileage as it gets loose with mileage. years ago a auto with 3.79's was the about the same as 4.11's in a manual on the engines rpm's at a given highway speed. Autos eats more hp than a manual which is all over the board as I have read as much as 60 hp, all guessing i'd say.
Old Dec 1, 2006 | 10:38 AM
krewat's Avatar
krewat
Carl, I've been over 5000... with 33's.
To keep it on topic:
A small column mounted tach is what I used ...
Old Dec 1, 2006 | 11:27 AM
"Beemer Nut"
Are you talking 3 speed only or a T-18 / 435 as a giant 3 speed with the non synchro granny low?
With your 4.11 gearing and tires you should be taching 2,721 @ 65 mph, should you go to 3.79 gears 2,509 @ 65 mph.
Your below the 3,000 zone which will eat the fuel but again you only have a 390 and come up short of torque available with wind resistance alone.
That is where 3.54's with a manual box and a 3.98" crank comes into play, 2,344 rpm @ 65 mph with a motor built for low end torque. I have broken into the 15 mpg range a few times with a 414, 3.54's with a C-6.
Old Dec 1, 2006 | 12:29 PM
mswift's Avatar
mswift
So, what is everyone's preference on the colummn mounted tach? Manufacturer? I'm not looking for a high priced one. Something in the mid price range.
Old Dec 1, 2006 | 01:32 PM
slinger34's Avatar
slinger34
I have a 2 1/2 in tach mounted on my dash. Its a cheap one and works fine.
Look at a Jegs magazine. They have tons of tachs.
3 3/8" Sunpro super Tach-$50
3 3/4" Autogage Tach-$50-$60
2 3/4" Autogage Mini Tach-$65
Old Dec 1, 2006 | 05:14 PM
guss's Avatar
guss
i have a autometer tach.it has a black wire a red wire a green wire a white wire.can anyone tell me where each one goes to.thanks for the help
