Installing Pyro help
Old Nov 21, 2006 | 06:44 PM
frnkln2003's Avatar
frnkln2003
I know this has been talked about before but since search is down I can't really look. I have actually been trying to get the time to do this for several weeks now but havent been able to. I am wandering where most of you located the thermocouple on your trucks.
Franklin
Old Nov 21, 2006 | 07:47 PM
Cuda_jim's Avatar
Cuda_jim
Pre turbo is where I have mine and 3 others installed for friends. Crawl under your truck on the driverside. Look straight up at back of the engine, you will see the exhaust manifold where it bolts to the up pipe leading to the turbo. Find a spot that allows a drill motor to fit. I drilled and tapped the manifold (cast iron) but you can put it in the pipe too. I did one on the pipe but it's thin so I welded a piece of 3/4 bar stock to it before drilling. This gives you more threads when it's tapped.
I used grease on the drill bit and magnatized it too. This collects most of the metal shavings. I then used a shop vacuum to get the rest of the shavings if there where any left.
Be sure the probe does not touch the opposite side of the manifold/pipe. It may give false or inaccurate readings if it does touch.
Old Nov 21, 2006 | 08:11 PM
frnkln2003's Avatar
frnkln2003
thanks, thas kind of where I was thinking it should go but just wanted to check.
Franklin
Old Nov 22, 2006 | 04:39 PM
cookie88's Avatar
cookie88
FTE Leadership Emeritus
FTE Emeritus
If you put it in the up pipe use a clamp on style mount. That way you don't have to worry about the tap or thread count.
Old Nov 23, 2006 | 05:21 AM
Cuda_jim's Avatar
Cuda_jim
I'm not a big fan of the clamp style, they have a tendency to leak over time. Leaks in the exhaust = loss of boost IMO.
Old Nov 23, 2006 | 12:22 PM
1997F-350's Avatar
1997F-350
HERE IS A GOOD WRITE UP FOR YOU
Old Nov 23, 2006 | 01:26 PM
cookie88's Avatar
cookie88
FTE Emeritus
I am a big fan of the clamp style. On the rare occasion that they leak it is easy to detect and easy to repair.....Unlike repairing a cracked cast iron manifold, anybody can replace a clamp and washer at home.
