65 352 exhaust manifolds
Old 11-20-2006, 11:57 AM
woodhd's Avatar
woodhd
woodhd is offline
I need to remove the exhaust manifolds to change the gaskets. Im having trouble removing them. I have soaked with pb blaster and also heated up the manifold with no luck. I have broke one already and dont feel like breaking more. any ideas to getting them off. Thanks...
Old 11-20-2006, 12:18 PM
Redmanbob's Avatar
Redmanbob
Redmanbob is offline
Keep breaking them and deal with it. The top ones almost always break as the heat has gotten to them and they stretch when moved at all. Right angle drill might be the only solution to the issue, unless you get lucky and have something to grab with a pipe wrench. I used longer grade 8 bolts when replacing so the end passes the top of the ear. Keeps moister out. If it will help in the long run is yet to be seen.
Old 11-20-2006, 12:23 PM
jowilker's Avatar
jowilker
jowilker is offline
The only way that I know is to heat them cherry red and start by rocking them between tight and loosen, gradually moving it more and more, and sometimes they still break.
No good answer.
John
Old 11-20-2006, 07:38 PM
Bob P1's Avatar
Bob P1
Bob P1 is offline
Let the truck run for a half hour or so, let everything warm up and keep soaking with PB blaster. There is also some penitrating oil called PDQ which works well. Take your time, time spent heating and soaking will be less drilling!!!
Old 11-20-2006, 08:37 PM
Torque1st's Avatar
Torque1st
Torque1st is offline
Posting Legend
Try the candle trick, it has worked for me. Just heat the parts so they smoke and melt a candle when touched to them. They don't have to be real hot. The candle wax penetrates the threads.
Old 11-21-2006, 05:03 PM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
Once you get them off, as mine seemed to easily fall off, don't put them back on with a gasket. Ford FE engines came from the factory without gaskets. Simply make sure the seating area on the exhaust manifolds are planed smooth and level. Some maybe pitted which will mean another manifold. That is what I did with mine then put them on with a little copper silicon sealer. Mine have been fine ever since without any exhaust leaks compared to when gaskets were used.
Old 11-21-2006, 05:30 PM
Redmanbob's Avatar
Redmanbob
Provided the heads show no pitting that would work.
Old 11-22-2006, 05:54 AM
jowilker's Avatar
jowilker
jowilker is offline
Say What??? Was this on 77 and later engines??
John
Old 11-22-2006, 07:50 AM
Redmanbob's Avatar
Redmanbob
Originally the manifold and head had only graphite grease between them as a sealer (no gasket) this requires fresh machined surfaces on both. Or for the engine to have sat in the garage for 37 years LOL....
Old 11-22-2006, 09:38 AM
woodhd's Avatar
woodhd
woodhd is offline
Thanks for the help. I might just have to take them out and the ones that break drill out. I plan on replacing all the bolts. There are no gaskets on them know and I thought that was why they were leeking. The out sides are pitted and rusted. I might have to replace the manifolds or by headers. does anyone know of a good header thats not to expensive...
Old 11-22-2006, 02:22 PM
ddavidv's Avatar
ddavidv
ddavidv is offline
When it comes to headers, good and cheap are pretty much mutually exclusive.
Most guys who have tried headers on the FE wind up hating them. When I sold headers (admittedly, long ago) the only brands I could reliably recommend were Hooker and Hedman.
Old 11-23-2006, 02:14 AM
tbm3fan's Avatar
tbm3fan
tbm3fan is offline
John
No, as my 67 Parklane does not have gaskets on the 410. Checking with people on my Cougar board, who are FE experts, all have said they were no gaskets used by Ford on these engines. Now just so I am not confused do you mean 77 and up (later) engines?
Old 12-04-2006, 04:11 PM
camperspecial65's Avatar
camperspecial65
camperspecial65 is offline
What I did was, like has been mentioned before...heat engine up and soak the heck out of them...PB blaster and nearly every thing else...did that quite a bit over the course of a couple weeks...then I took it to the shop and had them do it...no broken bolts and no broken ears...
My logic in it was if they broke while they were working on it...its their nickel to replace parts...i.e. heads if an ear broke...
No gaskets were used as was said above originally....
CS65
Old 12-05-2006, 08:22 AM
Flyn66dtmn's Avatar
Flyn66dtmn
Flyn66dtmn is offline
another suggestion is if you can reach it with a hammer hit the bolt head a good lick. it breaks the rust bond in the threads. if the engine is in the pickup most of them will not be accesible to do this. learned that from an old mechanic and have done it numorous times and it works abot 80% of the time. also i would recomend using high performance gaskets as they are a little thicker and may save you have to have the manifold shaved. also use a antisieze thread lubricant going back together. makes future work on it much easier.
Old 12-05-2006, 08:49 AM
woodhd's Avatar
woodhd
woodhd is offline
Thanks for the idea. I'll give it a try...
Quick Reply: 65 352 exhaust manifolds
