starting problem
starting problem
I have a 1988 ford truck with a 302 switch out to a carb setup I am recently having problems starting its either the timing or battery how much volts does a battery need to have crank you motor. It really only does it when ive been driving it around for a while seems like timing but have set it alot of times Ill set it at 11dg. without the vac and goes to about 36 dg with vac. adv. All wire from the battery are 4gau. or maybe the battery is no good its been on since I bought it 2yrs ago and who knows how long its been on before I bought it.
