Strange problem
Old Nov 7, 2006 | 06:02 PM
94 superduty's Avatar
94 superduty
Strange problem
Last night I was driving home and it was getting dark. So I
turned on my headlight and my truck started to lock and unlock my converter. When I turned off the light it would stop. I check to see if my brake lights where on. I check to see if my turn light would make it do the same thing. It didnot make it do it. If any one has Idea on this or if anyone
has had this happen to them. Thanks
Old Nov 7, 2006 | 07:56 PM
PLC7.3's Avatar
PLC7.3
Did you have the 4 ways on............
Old Nov 7, 2006 | 08:48 PM
94 superduty
No, The only thing I had on was the lights.
Old Nov 7, 2006 | 10:24 PM
PLC7.3's Avatar
PLC7.3
I would advise checking the main light switch connector for burned condition...... then the BOO switch on the brake pedal (brake on off). The below article takes a lot of power away from the light switch/connector directly and saves it from burning up.
https://www.ford-trucks.com/article/...r_Brights.html
Old Nov 8, 2006 | 06:11 AM
pnose's Avatar
pnose
also check the bulbs to be sure the filiments arent touching eachother.
Old Nov 8, 2006 | 06:50 PM
94 superduty
Thanks I will check lt out.
