Max compression
Old Aug 13, 2006 | 12:58 AM
WarWagon's Avatar
WarWagon
Max compression
What would you feel would be the max compression for an iron head 351 on 87 octane? Consider a tow rig with a 270 cam. I'm figuring 9-1 max with tight quench, but I still may be high.
Old Aug 13, 2006 | 03:39 AM
roger dowty's Avatar
roger dowty
I think thats probably about right for heavy towing application-but it all depends on when the intake valve closes ie swept volume in determining dynamic compression. I wouldn't see 9.5 as an issue towing with the right 270 cam- as it drains off quite a bit of compression.
I going 9:1 with a stock cam but 1.7 rockers for a bit more lift and 289 hipo heads. It should be in and running in a week or so.
