Speedometer
Old Aug 2, 2006 | 10:24 PM
1ford1's Avatar
1ford1
Speedometer
I changed my rear end...3.00 to 3.50. How do I correct the speedo?
Old Aug 2, 2006 | 10:27 PM
MBBFord's Avatar
MBBFord
You need a new gear. If you have a 2wd, then follow the speedometor cable to the trasmission, and if you have a 4wd, follow it to the transfer case.
It shouldn't be off much, Just show your going about 75 when your really going 70(and that should be about the worst).
But either way, broncograveyard.com sells them, and they have a way to calculate which toothed gear you need to swap in place.
Old Aug 2, 2006 | 10:30 PM
1ford1's Avatar
1ford1
Thanks for the info... I will try that.
Old Aug 3, 2006 | 12:07 AM
Mil1ion's Avatar
Mil1ion
http://www.tciauto.com/tech_info/speedo_gears.htm
Bottom of the page
