Strange Problem
Old Jul 25, 2006 | 06:17 PM
pokerpuller's Avatar
pokerpuller
Strange Problem
Today has been a very bad day to be my truck. First I had a problem with vapor lock, now it seems to have moved into a whole other ballpark.
The motor runs great in park.
When shifted into drive it either bucks wildly or just stalls. Even if you take your foot off the brake.
The kicker: It works great in reverse.
What's wrong?
Could it be heat? Its very hot here today and I have a cat right next to the tranny/cooler lines.
-kit
Old Jul 25, 2006 | 07:21 PM
Mil1ion's Avatar
Mil1ion
Vacuum or Transmission Vacuum Modulator .
Old Jul 25, 2006 | 07:47 PM
Torque1st's Avatar
Torque1st
Posting Legend
Someone had a similar problem and it was traced to a wire shorting when the engine moved as it was put in gear. Another person had a similar strange problem with a broken wire inside the distributor. Another person had an internal valve body problem in the transmission. -Take your pick!
Old Jul 25, 2006 | 08:54 PM
pokerpuller
Problem discovered! The movement of the engine was sawing through/pulling apart the red wire to the ignition coil. Just jumped it with 12V from the battery to get the 1/4 mile home.
-kit
