275 70r 18 VS 275 65r 18
Old 07-13-2006, 08:59 PM
whododat's Avatar
whododat
whododat is offline
What is the difference in the 65r vs 70 in this tire size, is the 65 wider or something else
Old 07-13-2006, 10:00 PM
weldman's Avatar
weldman
weldman is offline
The difference is the height, as the 65 and 70 are the sidewall height expressed as percentages of the section width (275).
The 275/65r18 will be approx 32.1 inches tall.
The 275/70r18 will be approx 33.2 inches tall.
You are scaring me by comparing these two sizes, as most times the 275/65r18 comes on the f150 and is Pmetric and the 275/70r18 comes on the f250 and is LT (E) rated.
They shouldn't be interchanged, unless you want a really rough ride on the F150, and a DANGEROUS situation on the F250, where the tires will not hold up to the loads the truck is capable of.
Old 07-14-2006, 06:48 PM
whododat's Avatar
whododat
whododat is offline
tire
No they are on my 2005 f350, i was thinking about going to a wider tire and not taller, just to keep things status qou w/ the speedo. I have the 275 70r 18's.
Old 07-14-2006, 07:07 PM
weldman's Avatar
weldman
weldman is offline
Are you looking for a more aggressive tire too? A lot of guys with the Continental OE tires are looking for that!
The only tire that is close to the 275/70r18 is the BFG All Terrain KO that comes in 285/65r18 D (a E ply will be available in the fall).
It is 10mm wider (and it will look a good deal wider because of the shoulder lugs). It will be 32.6 inches tall.
Old 07-16-2006, 04:38 PM
whododat's Avatar
whododat
whododat is offline
yes weldman i am loking for a more aggresive tire,
thanks
Old 07-16-2006, 04:42 PM
weldman's Avatar
weldman
weldman is offline
The KO would fit the bill then, just make sure to compare the load ratings to make the best choice for you. If you tow a lot of weight, you may want to wait for the E ply.
Old 01-13-2022, 05:40 PM
chadinnc's Avatar
chadinnc
chadinnc is offline
Snow chains
looking for information on snow chains for F250
I have some news and snow chains I had for my F150 that work for a size 275/65/70. But don’t know if that will work for my F250 275/70/18.
I called the manufacturer and they said to try them but could not tell me if they would fit or not.
I hate to open up the new chains in case they do not fit.
any advice or suggestions.
thanks Chad
whododat;3810081]What is the difference in the 65r vs 70 in this tire size, is the 65 wider or something else[/QUOTE]
onug
2015 - 2020 F150
15
04-13-2017 09:18 PM
Magnus E
12-01-2016 08:27 AM
RickyC8443
2009 - 2014 F150
11-20-2012 09:30 AM
Skoiv
2009 - 2014 F150
32
12-15-2011 06:45 AM
WindLight
2009 - 2014 F150
03-12-2010 07:26 PM
Quick Reply: 275 70r 18 VS 275 65r 18
