diff. in rear ends
Old 10-21-1999, 07:38 PM
rodney's Avatar
rodney
rodney is offline
diff. in rear ends
Is there a difference in rear ends from a 72 F100 to a 73 F100? Did they even have 9inch rears in 72 trucks?
Old 10-22-1999, 08:30 AM
jowilker's Avatar
jowilker
jowilker is offline
diff. in rear ends
Rodney the rears are the same 9 in in the 1/2 ton 2wd. The gear ratios are different for engine size, auto vs sd transmissions.
>Did they even have 9inch rears in 72 trucks?<
Yes and before that.
John
Old 10-22-1999, 03:03 PM
Brad Conley
Guest
Posts: n/a
diff. in rear ends
Old 10-22-1999, 11:29 PM
mk's Avatar
mk
mk is offline
diff. in rear ends
It seems to me that Ford used a Galaxie rear end in the F trucks up to 72. The 73 and up rearend housing is 4 inches wider. The center sections will interchange without trouble. I believe I've read about different depths of center sections but if you stay with a truck gearset you shouldn't have trouble. I'm currently checking to see if the spring mounts will fit from a 73-9 back to a 67-72 frame so I can put the wider rearend in my 68.
Old 10-23-1999, 04:53 PM
timpage's Avatar
timpage
timpage is offline
diff. in rear ends
Yes, 9 inch rears have been around since 1957 (at least in F series trucks). The only difference would be if you have a Dana 60 rear, as some F-100's did have a Dana 60 with a 5 bolt wheel pattern. My friends 65' F-100 is set up with a Dana 60, and so I wouldn't know why they wouldn't have continued to do the same thing up into the 1970's.
tractormanbill
22
10-02-2014 02:29 PM
72sleeper
06-24-2013 06:48 AM
barrett74
04-01-2013 03:17 PM
hagadornclassics
06-26-2010 08:04 AM
Pup
07-28-1999 06:16 PM
Quick Reply: diff. in rear ends
