Hey guys. Wanted to see if anyone had an idea about what my brake problem is. Did a search and couldn't find anything. After installing my lift kit and larger tires a few months ago I noticed the first time I drove the truck that when you depress the brake pedal it has a slight detent feeling. Hopefully you know what a detent is as I really don't know how to describe it. The truck can be on or off and just as you start to depress it is hangs for a second and then pops past the problem.
No longer brake lines installed. It actually feels like it is in the pedal assy. It happens when you first depress it, like where the slop would be before the brakes actually would start doing something. The brake pads and the rest of the system do not have any pressure yet. Thanks for the reply.
Yea, actually I do have the adjustable pedals. I never move them so I will try that tomorrow and pull the panel and look for anything obvious. Hate to take it in if I don't have too.
