Front end alignment
Old May 28, 2006 | 08:38 AM
jd_sylvia's Avatar
jd_sylvia
Front end alignment
Hey guys and galls.
I just finished going thru my front end on my 65 f100 twin I beam new bushings and shocks with new tires.
Does anyone know of a good shop in the valley that does a good front end alignment on a twin I beam truck?
Jon
Old May 28, 2006 | 11:59 AM
WillyB's Avatar
WillyB
You need to take it to a heavy truck shop - only they have to tools to bend the beams as needed. There is a very good one in Fresno, but you should be able to find one closer to home.
You can set the toe-in yourself, and do as good a job as most shops.
Old May 31, 2006 | 07:19 PM
3Mike6's Avatar
3Mike6
There used to be a place where Coffee ran into Scenic, called Scenic Wheel and Brake...it's gone now, but I'm pretty sure when they moved, they either kept the same name, or mentioned "formerly Scenic Wheel and Brake", they used to do my staright axle trucks way back in the day.
If no luck fnding them now, call Neville Brothers, Larry used to be into 40's and 50's Chevy PU's, and could probably steer you (pun intended) in the right direction.
Old May 31, 2006 | 08:09 PM
jd_sylvia's Avatar
jd_sylvia
Thanks guys will check out Senic Wheel and brake I think they moved out to Empire on Yosemite.
Thanks Mike
Jon
ALedbetter1
Feb 28, 2014 02:06 PM
NarleyHarleyGuy
Feb 8, 2013 02:03 PM
sparkles
17
Nov 23, 2007 03:48 PM
Scottmiester
Virginia Chapter
May 28, 2006 10:21 PM
