1966 - 1977 Early Broncos
Electical problems
Old May 27, 2006 | 04:59 PM
Devildragon's Avatar
Devildragon
Electical problems
Hey guys its been awhile.
Ok so here it is, I have replaced my battery, starter solenoid, voltage regulator, and I have tested my alternator(good), my baby still won't keep a charge. I just hooked the battery up to a charger and when it gets fully charged I'm going to start her up and see if it will hold the charge since I just replaced the voltage regulator, if that doesn't work then what can it be? I have a good ground so I know thats not the porblem. I also know that our broncos don't have the best electrical systems put its really startin to be a pian in my butt. if anyone has any ideas or has had this happen to them before let me know. Thanks for the help guys.
Old May 28, 2006 | 09:48 PM
RCrawler's Avatar
RCrawler
Is it not charging or do you possibly have a parasitic current draw? Have you tested charging voltage and amps at the battery while its running? Do you have a complete circuit through the ammeter? Is the wiring from the alternator to the regulator intact? How about the wiring at the starter solenoid?
What year is it? I can send you a wiring diagram if you need.
Jason
Old May 30, 2006 | 03:48 PM
Devildragon
thanks for the help but its runnin great now I guess all it needed was a new voltage regulator, I'm never takin her to a mechanic again.
brian1985f150
19
Feb 7, 2017 05:52 PM
brettdacosta
Mar 5, 2011 07:47 AM
brettdacosta
Mar 4, 2011 09:33 PM
josh390
18
Nov 8, 2008 04:03 PM
jimbo81587
Electrical Systems/Wiring
Nov 18, 2004 02:32 PM
