Hey BLuegrass, can you take a look at this thread i started?
https://www.ford-trucks.com/forums/1...l#post16842355
I think i found a harness but i do not know if its the right one. can you look at it?
Thanks!
Thanks!
Sorry I can't tell from photos.
If it has the same tag ID # your good to go.
Pull yours off if the truck is not usable so you have it to compare with.
Any harness has to connect to the EVAP system, both rear Ox sensors, both front Ox sensors and plug into the transmission for shift control.
Good luck.
Good luck.
02GrayPowerStroke
1997 - 2003 F150
02-07-2017 03:49 PM
02GrayPowerStroke
1997 - 2003 F150
01-05-2017 01:01 PM
Cruiseomatic
11-21-2016 07:28 PM
jeeplj8
02-10-2011 11:42 AM
