help with eec
Old May 13, 2006 | 09:52 PM
hatchetman2268's Avatar
hatchetman2268
help with eec
I have a problem with my 1982 f-150 eec-3. Truck wouldn't start the other morning so I took another ride to work.I screwed up and left my ignition on all day and drained the battery.Now after getting the battery charged testing the tp sensor I have no reference voltage to my sensors.Could I have damaged the computer or is there somethig else to look for.Thanks for any help.
Old May 14, 2006 | 08:49 AM
subford's Avatar
subford
Make sure your EEC Power Relay is making when you turn on the key and that the Black wire with a red stripe has power on it going into the Power relay.
If both Red wires have Power leaving the Power relay then your EEC (ECM) may be bad.
