Flame throwers?
Old May 4, 2006 | 11:18 AM
chrisBnn's Avatar
chrisBnn
Flame throwers?
Has any body know how to make flame throwers? I want to make one using propane since gas is so expensive
Old May 4, 2006 | 11:33 AM
Mil1ion's Avatar
Mil1ion
If you do a search in this thread about Flame throwers ....4 threads should show up.
Old May 4, 2006 | 12:30 PM
eedvark's Avatar
eedvark
Fill a Chevy with gasoline and throw a match on it.
Old May 4, 2006 | 01:58 PM
FordTrucksKickGM's Avatar
FordTrucksKickGM
Not this flame thrower thing again. Some one is going to end up blowing themselves up.
Old May 4, 2006 | 03:53 PM
broke77f100's Avatar
broke77f100
get a flame thrower kit from Auto Loc
Old May 4, 2006 | 10:33 PM
1967Ford300's Avatar
1967Ford300
im not saying this is safe, but this is what i have done. You will need an extra coil to hook up to either your regular battery or get a seperate battery and weld a bung in your exhaust about 1-1 1/2 feet from the tips, to put a spark plug in. The hard part is getting the fuel, or propane in the exhaust system safely, so the flame wont go back into where the propane is comeing from. I had a system jerry-rigged to work a few times, but probably nothing you wanna do.
Old May 5, 2006 | 01:24 PM
Mil1ion's Avatar
Mil1ion
Why is this in GC now ?
It's automotive related.
Unless he is asking about a general typr flame thrower like the military has
Old May 5, 2006 | 01:25 PM
hawk's Avatar
hawk
we had one when i was a pup, ran on kerosene pumped it up with air, lit it and melted the ice offa the drive-way!!
Old May 5, 2006 | 01:35 PM
hav24wheel's Avatar
hav24wheel
i an doing the same thing with my 5 inch stacks, i am useing a old pionts style distributor, hooked up to a 12 volt electric motor. you can run 2 coils form the one set of points. hook the + side of the coil to a swith along with the + side of the electric motor. hook the - side of the coil to the distributor, make sure the distributor is grounded. hook a plug wire up the the coil, put a plug 3 inches- 12 inches from the end of the exhaust pipe. i am popane injecting the bottom of the stacks with a fuel shut off valve from a fork lift, i got it for$20 dallars down town. hook the shut off switch to the same 12 volt switch that the electric motor is hooked to. flip the switch and FLAME ON!!! just make shure you don't start any thing on fire.
Old May 5, 2006 | 01:39 PM
hav24wheel's Avatar
hav24wheel
i tried a auto loc kit and it burnt out. used it for to long. they are ment for short intervoles. my way works how ever long you want to.
Old May 5, 2006 | 02:34 PM
broke77f100
did the auto loc kit shoot 20 footers out?
Old May 5, 2006 | 03:03 PM
hav24wheel's Avatar
hav24wheel
no just 1 footers, i didn't have the propaine hooked up.
Old May 5, 2006 | 03:09 PM
broke77f100
i think im gonna get an that kit for my 77 F100...better put a metal bed on instead of the wood one first though HAHAHA...that could be bad
Old May 5, 2006 | 04:05 PM
furball69's Avatar
furball69
Old May 8, 2006 | 10:30 AM
chrisBnn's Avatar
chrisBnn
I want to put them on my truck. Howwould i go about hooking up the propane so i can turn it on inside the cab?
