power brakes
Old 04-12-2006, 09:00 PM
f250red's Avatar
f250red
f250red is offline
power brakes
I would like to install power disc brakes on my F250 pickup.292Y block with an early 4barrel intake manifold I find no port to access manifold vacuum,was thinking about drilling and tapping manifold 1/8in. pipe ,also wonder if the vacuum was sufficent for a 7in.booster.
RED
Old 04-14-2006, 11:05 PM
buns's Avatar
buns
buns is offline
Hmmm. I have never seen an intake manifold without a vacuum hole. Seems odd. Anyway, click on the link below and you will see a picture of the back of a 1956 car intake. I don't know if you can tell from the picture, but there are two 1/4 inch holes inside the large hole. Perhaps to create a venturi effect? Your guess is as good as mine.
http://tinypic.com/vhaurm.jpg
Old 04-15-2006, 08:26 PM
f250red's Avatar
f250red
f250red is offline
power brakes manifold vac.
Thanks buns There is a manifold on Ebay item #4629345665 exactally like mine same part #ecz 9425-a. no sign of vacuum port either.not sure what year or model it came from,maybe someone out there might know
RED
Old 04-16-2006, 12:28 AM
buns's Avatar
buns
buns is offline
Is this the one? Yeah, can't see a vacuum source. Wierd.
http://i2.tinypic.com/vnduuh.jpg
Old 04-16-2006, 10:02 PM
buns's Avatar
buns
buns is offline
Thumbs up
Well, all I had to do was go out to the garage to get the answer. I have the same intake on my Merc. The vaacuum is sourced from the base plate on the carb. This is where I get the vacuum for the windshield wipers. Mystery solved.
jb78f250
07-27-2013 04:29 PM
Loswald
03-26-2004 03:58 PM
xuare
02-19-2003 12:13 AM
darkknight
11-17-2002 06:57 AM
Quick Reply: power brakes
