MORE MPG for 4.9L
Originally Posted by Cheggie
I follow all of the old fashioned guidelines regarding tire pressures, alignments and tuneups, and I do run synthetic oil and a K&N Filter. I have a five speed and a 3.08 rear gear. My consistent best from several statewide jaunts is 19.4 mpg. Usually about 65 mph
I have a 95. It has stock sized street tires on it, which probably helps. I also drive pretty conservatively. You have to look at the little details to get the most out of your fuel. If the truck pulls to one side it's going to waste gas. If you have "truck tires" they might not be as efficient. If you have an old O2 sensor it's going to adjust your fuel more slowly.
Until I get that tank selector valve replaced, it's hard to tell ... when I bought my 90 3 months ago I got about 15-16 on the 300 mile drive home at between 75 and speedo buried. I don't think I can do 60-65 .... in my car I am still in 3rd gear at that speed ... and the Turbo is cranking out about 16PSI .... I look at FPG in the Beetle .... that's Fun Per Gallon ... the only way to measure the extra cost of premium fuel.
Not a whole lot you can do to squeeze from teh stock engine build, period.
Since that engien has been around a while, probably not much over time was done to keep up with the times. So, it probably could use better head flow--porting/polishing, a cam and some rockers, probably a higher compression ratio...but let's find the specs first...
http://autos.msn.com/research/vip/sp...-150&trimid=-1
Engine Specifications
4.9L 145 hp I6
Horsepower 145 (at 3400 rpms)
Torque (lb-ft) 265 (at 2600 rpms?)
Valves/Valve Configuration No data
Displacement (cc) 4917
Bore X Stroke (in.) 4.00 X 3.98
Compression Ratio 8.8:1
Fuel Type/System No data/MPFI
Turbocharger No
Supercharger No
So, you've got an engine that has a good compression ratio for forced induction, but no forced induction. Bad. The engine needs revs to reach its peak ratings, but doesn't like to rev. Bad-Bad. You get the idea. For any real impovement, you have to get past cold air intakes and TB spacers...
4.9L 145 hp I6
Turbocharger No
Supercharger No
#30
yeah, the 2:73's suck for pulling, but i wouldn't go much higher. I'm wanting to put something like 3:08, or a 3:25. If you go too high you can't really utilize the torque in the lower rpm's. I'm suprised how the 2.73 rear end does, but it's way too low of gears in the 300....it's hard to outrun go-karts and scooter's. Old women out run me in the wall-mart parking lot.
