Sponsored by: Auxito
SEVERE ENGINE PROBLEM>>>HELP!!!!
Old Mar 21, 2006 | 11:02 PM
SGTdirtybum's Avatar
SGTdirtybum
hey all....
I thought you'd all appreciate the update with my situation. I ended up taking my truck down to an engine shop on the south side of S.A. and sure enough.... I had hydrolocked it and then when i started it up..... I not only bent the rod... I threw it... it went right through the oil pan and I'm now buying myself a new block....... this shop is going to replace with a re-manufactured block, replace water pump and all the installation kit needed... with labor... it's gonna run me $2100. Not too bad if you ask me...... just bummed out that it had to be done...
Old Mar 21, 2006 | 11:16 PM
150ford's Avatar
150ford
Will they warranty there work? I ma assuming they will but just wanna make sure. So the rest off the engine is alright? Good Luck an let us know how it all turns out for you.
Old Mar 22, 2006 | 08:18 AM
mnl119's Avatar
mnl119
Hope it turns out OK. That's a huge job with lots of opportunities for things to go wrong.
