General Diesel Discussion
check engine light
Old Feb 27, 2006 | 09:34 AM
leadsled's Avatar
leadsled
check engine light
I have a 96 ford psd and my check engine light come on and it seems like one of the injectors stops working it has no power and sounds real bad but the light goes off for a second or two it runs fine.Have any ideas or expierence with this
Old Feb 27, 2006 | 09:49 AM
IBeam's Avatar
IBeam
You need to run a test and see what trouble codes it is giving. Without the codes, an injector is only a guess.
Old Mar 3, 2006 | 06:11 PM
jwpsonoma's Avatar
jwpsonoma
It was my turbo
I have a 2005 PSD. When I'd go up hills, it would cut out & make this thrashing sound. (Like somebody was holding a broom to the fan blades) Then the check engine light came on. I took it in & they replaced the turbocharger. Been good ever since. Hope your still on warranty. Good luck.
John
