Nervous about pyro install
Originally Posted by jeffdoerr
if you do tap the hole, make sure you back the tap often, even every half turn, back up a half turn or more. You want to make sure you break off the millings when you back out the tap.. Nothing is worse than breaking off a tap in the hole, at least with damaged threads you can go larger.
this is good advice and also you want to check your thread depth because npt thread is tapered and you do not want to bottom out the probe to the manifold. since it is tapered it seals on the threads itself and if you bottom out the probe it will be sticking too far into the pipe and will not seal correctly. so dont put the whole tap in so it will thread in and out freely like a normal tap would
I am about to take on this task as well. I have a HOG Performance Pyrometer and teh temperature probe is about 1.5" long. Is this normal? It would seem to me that with all of the care we go to to get the airflow into and out of the engine quicker and smoother that a probe that size would cause some turbulence???
Originally Posted by dunnit52
What is the best way to properly get the thread depth for a proper seat? I'm installing an autometer pyro probe soon. What is the correct thread for this as well. 1/8 NPT?
Thread depth is never standard with NPT. You must drill and tap in a little ways and then test fit the fitting that you are going to use. If it looks good then you are done. If it's too tight then you must cut the threads another turn of the tap. Repeat until you can get it no more than halfway in without using a wrench.
Make sure you use the proper size drill for the tap. I didn't have the number drill so used the closest fraction drill. Broke the tap off in the manifold. Was able to finally back it out but was sweating profusely during the process. Stupid move considering where I was working.
you need a .339 drill which is an "R" drill. it is important to use the right size drill because if it is too tight the tap will break and if it is too loose the pyro will not seal correctly. also make sure you get the tap started straight once you have your hole drilled
I found the right sized tap (1/8" - 27) in town at Sears, but could not find the bit locally. I ordered the size R bit online from www.drillsandtaps.com You can also get the tap there, if you couldn't tell by the name of the site.
Originally Posted by Kwikkordead
I would assume that 1/8" NPT is standard for all brands of thermocouples.
Got my "r" bit ordered!!
Thanks Kwik....so what your saying is, for proper depth, the threads of the probe need to be so that it is tight w/o bottoming out? Maybe with a couple of threads still showing on the probe itself when tight?
I have talked to more peaple that say to mount the pyro sensor after the turbo because the sensor deteriorates and falls apart. Turbo probably wouldn't like to pass that. Has anyone else tread the instructions to there gauge kit.
The instructions that came with the guage do say to mount it post turbo. However, your most accurate readings will come from a pre turbo mount. Also, I have never heard of anyone who has a probe mounted pre turbo in a PSD that has had the probe break off.
Originally Posted by 4X4 IN REFUGIO
Post Turbo Readings are Accurate..... You're Just Dealing With A Different Temperature Range. A Lower Temp Range And The Temp Range Is Lower Because Of Where You're Reading It From. However The Pre Turbo Readings Are More True To What The Temp Really Is Closer To The Engine.
Anyway... A Post Turbo Reading Can Be Just As Usefull To You If You Know What Temp Range Your Working With My .02 Cents
i wouldnt be too concerned about a pryo probe melting and breaking off because i believe they are made on inconel which is a very heat resistant metal and has to get well above 1200 degrees to even begin to start melting. i dont think there is anything to worry about. i havent heard of anyone having it break off
