engine/trany combo
Old Feb 15, 2006 | 11:08 PM
messticle's Avatar
messticle
engine/trany combo
What is a good engine that will work in a 76 F250 with either a NV4500 or a NP435 trans for weekend driving only towing trailers over mountain passes. I have a 300 6 cyl. and a 400 that came with the truck but I'm thinking a 351C or a 460. Maybe 390? I need good horsepower and torque with decent mpg.
Old Feb 15, 2006 | 11:26 PM
Mil1ion's Avatar
Mil1ion
A Pre 1972 429/460 will give you all the power you will need.
A beefed up 400 will achieve unbelievable HP & Torque.
https://www.ford-trucks.com/article/...00_Engine.html
A 60's 390 will certainly do well too.
Old Feb 16, 2006 | 11:48 AM
Torque1st's Avatar
Torque1st
Posting Legend
What engine is presently installed in the truck?
Old Feb 16, 2006 | 12:29 PM
fordraceboy's Avatar
fordraceboy
a FE motor is the only drop in affair if it's a 4x4... they do make kits for an easy conversion to a 385 series motor(460).. it depends on how in depth you want to get with a motor swap... 390's will pull good with a np435, that's what i run.... 400's and 460's make good power but as i noted above, aren't usually a drop in affair... JMO
